How to configure wifi connection for monitoring
I have the 2.5Gbps Hardware Agent.
There is supposed to be an option for enabling the wifi connection.
However I am not finding a location in the menu where that can be enabled.
Screenshot is attached.
Great, I was able to configure the wireless. How would I now switch between wired and wireless?
Two things:
- anytime the agent reboots (this happens once everyday at 3:00 am UTC) it will start from wired and then will move to wireless i.e. you will always need a wired connection for the agent
- you can switch from wired, wireless or AP anytime from the same configuration menu
