  5. Speed Test
Speed Test
hardware agentextended levelspeedtest
4 Posts 2 Posters 775 Views 2 Watching
  • M Offline
    M Offline
    mactoys
    I just received the Hardware agent, along with a one subscription to the extended reports. I pay for 200 Mbps Internet from my ISP. Two issues:
    • I get an notice indicating "configure speed test" doesn't match what is measured.
    • The reporting also is way below my ISP bandwidth. I can test manually and via my wireless devices. Both show nearly 100 Mbps more than being reported on this solution. Thoughts?
      The hardware agent as noted in the sales page, has a maximum of 100Mbps port so you won't see more even if you have that. Because you've set the minimum based on 200Mbps, is why you are seeing the notice.
      Now, here is the trick and it works well for most people.
      Why fully saturate your connection anyhow, that will use up your data and bandwidth just testing.
      The best thing would be to set the bandwidth for 100Mbps and set the low notification to close to the 90+Mbps that your agent can do.
      This way, you'll be notified when your speeds actually do go lower than expected but without using up so much of your data plan and bandwidth. You'll know if your provider is dipping below that point which is still very usable bandwidth.
      I hope this helps to explain but please feel free to ask anything you need.
      • M Offline
        M Offline
        mactoys
        Thanks. I mis-read that info. I thought it was an issue that was being worked on. I'll make those changes. Thanks
          You're welcome.
