  5. how to read dashboard
dashboardinternal vs exthow to read
64 Posts 3 Posters 61.1k Views 3 Watching
  • D
    D
    dberges
    ok, created and seems to be working on an old laptop.
    • D
      D
      dberges
      So i restarted on my old laptop (where i'm the admin for sure) with agent 1293559 about a week ago. I still have multiple short outages per day and they seem to coincide with the gaps in the ping chart (when i get an outage, i come check to see if it was recorded). But the other charts show what seem to be very few and different times.
      But the ping chart only shows 4 hours, IF it's the right way to track outages, is there more history available?
      D 1 Reply Last reply
      • D dberges
        D
        D
        dberges
        @dberges here's a hop list from 3:30p
          As explained earlier, when you see disconnections but no outages, it means anything but IP outages. Those links I shared explain what some of the causes could be, bad or slowly failing cable, firmware needing an update in your firewall or router or modem, or your provider has a signal level problem at the street level and they aren't acknowledging the problem.
          The only way to know more in your case would be to get one or two neighbors to install an agent also so that we can correlate their data.
          To get more info, you could always upgrade your reports for 30 days and that will show you historical data and other information that may or may not help. It may not help since you seem to be experiencing problems which aren't specifically IP related so the agent cannot log those, it can only tell you that's what seems to be happening.
          You can know this because of what you aren't seeing, IP outages that would be logged by the agent.
