  5. how to read dashboard
dashboardinternal vs exthow to read
64 Posts 3 Posters 61.1k Views 3 Watching
  • D
    D
    dberges
    Yes. It’s been on the whole time
    • D dberges
      #42
      I'm asking if you were on the same PC that the agent is installed on while looking at your dashboard and seeing the agent Disconnected or using another PC/mobile/tablet.
      Thanks.
      D 1 Reply Last reply
        Thanks.
        D
        D
        dberges
        Same laptop. Had to restart it once for a program lockup. Otherwise it’s always on[link text](link url)
        • D dberges
          @dberges
          If the agent showed Disconnected but you were still able to get access to the OutagesIO dashboard, then I suspect that the agent is stopping on that laptop.
          The next time you see it Disconnected, and again, from the same laptop, can you please fire up a command line prompt and ping one of our servers.
          ping tpw.outagesio.com
          This must be done at the exact same time as you see the agent saying it's Disconnected.
          • D
            D
            dberges
            Still disconnected so did as you asked.
              Ok, so now, please restart the Echonetworks service and lets see if the agent comes back online. Just use the restart option.
              • D
                D
                dberges
                sorry, what is echonetworks? where/how do i find it?
                  Google starting, stopping services for your operating system. Then go to the Services area on your PC.
                  Please report back if it said it was or was not started while at the same time confirming that the OutagesIO dashboard is still showing the agent as Disconnected.
                  Then use the Restart option only to restart the service and let us know if the agent has changed to Active in your OutagesIO dashboard.
                  • D
                    D
                    dberges
                    echo was running when i went to service list (and agent was still disconnected. i restarted echo and now agent is active. what had i done wrong??
                      Can you show me a screen capture of the service please.
                      • D
                        D
                        dberges
                        you mean of all the "running" items on service?
                        • D dberges
                          #52
                          No, just fire up task manager then show me the running task. It'll be otmxxxxx.
                          I think you showed it earlier on but if you can do it again please.
                          • D
                            D
                            dberges
                              What I'm looking for is the owner of the otm* process or processes. You would have to Google how to find that on your OS. I don't know Win 10 or 11.
                              • D
                                D
                                dberges
                                this do anything for you?
                                • D dberges
                                  Right click on the OtmServiceApplication and see if you can change the owner to system.
                                  • D
                                    D
                                    dberges
                                    nope, can't figure out how. i think this project is just way to advanced for me. thanks to you and Ed for all your attempts to help, i think i just need to whine to AlticeOne and live with what i get.
                                    Dave
                                      One thing you could do is fine a friend that is a little more technical.
                                      About the only problem we seem to be having is that the agent doesn't seem to have been installed with full admin rights as is required and noted in the installation notes.
                                      Outside of that, it seems to be running as it should be.
                                      • D
                                        D
                                        dberges
                                        i do have some weird problem with admin rights. can't get this dell rights back, lost the code. I'm going to delete this one and put it on my old machine where i know i have admin rights and can leave it.
                                        • D dberges
                                          That is an important thing.
                                          The agent must be installed using an account that has full administrative permissions on the PC otherwise, the installer won't be able to create the firewall rule needed to allow the agent to communicate with OutagesIO.
