Speed testing not working
I noticed that the Speedtest has not been working for some time. Are there any issues with it? I have a hardware agent.
Thanks,
Hi, oddly, no one was notified of this post.
Can you provide more information so we can look into it. Agent ID for example? -
Thanks,
@markl
The only agent that has Extended, enabled to use speed test is 128666 and it is working correctly since may 16.Maybe there is something else that we're not seeing? Could you please add some details to better understand what the problem is?
@markl
