Agents is running but not reporting
I don't think anyone is 'lost', but we obviously got out of sync and I made an error in what I said.
Just try the current version on any servers you're still having problems with. That way we don't have to think about previous versions and move forward again.
If you have any servers running the new version that have problems, please look at the Windows logs and send what you can.
Also, get rid of that logging version, it's useless at this point and is only useful while we're monitoring a specific version.
I have 23 endpoints online right now and only 5 are reported active on your portal. One endpoint is running latest version of your client but is reported disconnected from outages.io portal. And it's not a connectivity issues because I can ping tpw.outages.io from those endpoints.
I'm getting tired of this. I've spent so many hours troubleshooting your software and you're not even able to follow properly on the issues. I was already using v1.77 with logging enabled and it is still sometimes crashing. I sent you the logs, you said you identified the issue and now you're telling me it was fixed in v1.75 ! This is a complete non-sense, I sent you logs of your app crashing from v1.77 !!!
Trashing us publicly for trying to help you doesn't make any sense. You told us you have had up to 30 agents running and said it was great that it's free.
As an admin yourself, surely you can appreciate the complexity of this problem. Even as a free member, we are still committed to helping because we want to find and solve the problem.
The problem is not widespread. If it was, we would be hearing about it a lot but we aren't. You are running 2016 servers and it's quite the task to have a single software that runs across all Windows versions.
Losing track is easy because it's a very long thread, and we've made other updates in some of the releases. The dev told me it was fixed in 1.75 but the log you sent us was 1.77 so clearly there is simply something that got out of sync.
If the agent is not working for you, we do not know why. I can tell you that the Windows dev has been working on yet another release to try and improve the fixes recently made but I don't know if that will solve why only some of your agents are not working right.
I'll reach out again to try and find out what he meant by pointing out 1.75 as being fixed.
