  5. Agents is running but not reporting
Scheduled Pinned Locked Moved Windows
agentwindowsreports
142 Posts 4 Posters 215.9k Views 3 Watching
    In both those logs, the agent just stopped communicating.
    It wasn't experiencing a problem internally at least but the service either stopped abruptly or something blocked it so it could not continue.
    Really not sure what is happening at this point.
    Is there any MS tool you could use to monitor the service so that we could get more information? You said nothing ever shows up in the server logs but we've never seen that happen. Not sure why this is happening either.
    If we could get more system logs, that could help find what ever is happening and fix it if we know what it is.
    All I can think of is that this version of MS is somehow different than newer versions but we spent months looking at this, making a few changes but now you're still seeing this.
    I did a quick search and there are tools for MS that can help find the cause of crashing services/processes.
    For example;
    https://techcommunity.microsoft.com/t5/ask-the-performance-team/what-killed-my-process/ba-p/375329
    L
    L
    lp4y
    I can try that and also share system logs but I would like some guidance (what to export, do I need to put any filter, what to configure with the process monitoring tool, etc)
    Also, the process is not crashing or anything, I can see OtmWinClient.exe running. It just need to be restarted to report again. The problem is occurring less frequently than with the previous version of the agent for sure, but it is still happening sometimes.
    • L lp4y
      I'm sorry, I don't know how to use it, just something I found on the net doing a quick search.
      All MS server products should have tools that help monitor processes to find problems.
      The point is that there are tools available that can monitor a process on a deeper level to figure out what is happening.
      Really not sure what to suggest. I think I would first suggest that you uninstall the logging version and throw it out since it won't be of any value. Get back to the normal version that you can download from the site and see how that goes.
      The logging version isn't meant for long term use anyhow as it has a lot of extra baggage just to try and log what it's doing.
      Maybe going back to the standard version on that server will solve the problem since you mentioned this doesn't seem to be happening so much lately with the new version.
        It turns out the dev was able to see something in the log you shared and is testing something now.
        He says it was very useful so hoping we'll see a fix soon. It takes a while to test but as soon as possible, I'll share the update with you.
        L 1 Reply Last reply
          L
          L
          lp4y
          Ok, I'll wait for an updated version
          • L lp4y
            L
            L
            lp4y
            One more thing, it's very time consuming to update the agents because for each server I need to uninstall the current agent, get new keys from the portal and then install the new agent. Would it be possible to make it more simple ?
            • L lp4y
              Believe me, we've worked on that so many times and what you see is the simplest we've been able to make it to date. This was after trying over a dozen different ways.
              The keys are mainly to ensure that the agents are installed to the correct account. If the software didn't have to be tied to the application site, then it would be simpler but you would not have a central place to check on all locations.
              Most people don't care because they have only one or two agents and typically, companies use the hardware agent which automatically updates itself.
              By the way, the logs you sent were absolutely helpful. The dev was able to notice a condition that sends the service into a sort of spiral with backed up processed internally.
              We'll release another update after testing. We're trying hard to get to what we call the final version.
                L
                L
                lp4y
                Ok it's good you identified the bug and working on a fix. Hope we'll get to a stable agent at some point.
                FYI for other tool that require an agent (Action1 or Itarian for example), I can directly download a customize agent from their website and my credentials are embedded in the installer. I just need to execute it and there is no need to input any credentials during installation or after, and the agents are self-updating.
                I understand you don't have this use case now and you don't want to spend time on it, but just to let you know it became quite an industry standard nowadays.
                • L lp4y
                  There are a lot of things we'd like to add and something like this could be done but we simply don't have the resources at this time.
                  Most of our members are using the service for free while development and ongoing costs are very high. We actually want to have a free version that can help people and want to add features that organizations would be willing to buy.
                  We have a hard time advertising, constantly being outbid by large ISP's and outage sites that would prefer people never learn about a service like ours. We work mainly by word of mouth advertising.
                  I think it would be a good idea and I'll pass it along to development but I think you are the only person that's asked about this.
                  BTW, if the hardware agent could work for you, you don't have to ship them around the world. If you can buy them to have them shipped inside each country you are in, we offer a service where we could prep them from remote for $20.00 each.
                  This way, you would not have to update software, it would be done automatically each time there is a release.
                    L
                    L
                    lp4y
                    wrote on last edited by lp4y
                    #129
                    No problem, I understand all of this.
                    I am not interested by the hardware agent because :
                    1. delivery in our countries and each center will be very complicated to manage
                    2. adding hardware in the existing computer rooms will look like additional complexity for the people working there who are afraid of touching digital equipment
                    3. I like to have the agent on the server because there is sometimes a problem with the network cable of that server and your tool enables me to detect it.
                    • L lp4y
                      I only brought it up because it might work at least in some locations for you. In terms of installation, they simply to connect it to a free DHCP port.
                      Anyhow, I have some good news. The log you sent seems to have been a lot more useful than I thought.
                      The dev found two things that could spiral some threads out of control causing the agent to stop communicating.
                      It would explain why in some cases, it looks like the service is down but it's actually not, it's the agent itself that is stuck. In other cases, it might cause the service to get shut down depending on what's running on the server.
                      This kind of problem is the worse possible because it's so random making it very hard to test as the only thing we can do is wait for it to finally misbehave.
                      So it seems there will be another update as soon as this is fixed.
                        L
                        L
                        lp4y
                        I'm glad you found the cause of the issue. I'll wait for you to release another update.
                          You can remove any logging versions you have at this point and go back to the normal download one.
                          The special logging versions become useless once we update on our end.
                          The log definitely helped, it just takes a while to test since this is a problem that's eluded us for quite some time as you know.
                          • L
                            L
                            lp4y
                            Hello
                            Have you been able to find a fix ?
                            • L lp4y
                              Hello
                              #134
                              @lp4y
                              Hi, This time, rather than putting out multiples thinking it's fixed, we're taking extra time to test.
                              It's the most perplexing problem we've had with the agent and it's been hard to find because we're trying to support so many MS OS's.
                              Let me reach out to the Windows dev and get you an update.
                                He tells me that the last version was supposed to have fixed that. Are you running it on any servers you had problems with?
                                  From the Windows dev;
                                  That crash was fixed in V1.75.2205
                                  V1.77.2207 (16.Dec.2022)
                                  Can you please check which versions are still giving him problems and if he knows of any issues in V1.77.2207?
                                    L
                                    L
                                    lp4y
                                    #137
                                    That doesn't make sense, you said the dev identified the problem and was doing some tests on January 15, so after v1.77 was released.
                                      #138
                                      I might have lost track because we're working on another release to update non Windows versions.
                                      However, he says he thought this was fixed. The ones that you're still having problems with, are they updated to the latest release?
                                        L
                                        L
                                        lp4y
                                        My agents are on v1.76 and yes problem is still happening. I sent you the logs and all, you said the dev identified the problem. Then no news. Just read again the messages in this thread because you seem lost.
                                        • L lp4y
                                          #140
                                          I don't think anyone is 'lost', but we obviously got out of sync and I made an error in what I said.
                                          Just try the current version on any servers you're still having problems with. That way we don't have to think about previous versions and move forward again.
                                          If you have any servers running the new version that have problems, please look at the Windows logs and send what you can.
                                          Also, get rid of that logging version, it's useless at this point and is only useful while we're monitoring a specific version.
