| Support forum notice: support.outagesio.com is now support.isptracker.com. Create a forum account and start a topic for ISP Tracker support. |
ISP Tracker explains what happened, where the problem appears, and whether it keeps happening.
Learn more
Agent installation problems
Is the agent communicating properly?
No hops and/or no pings
One way of knowing if your Windows agent is not working is if you do not see 'sending updated hops' in the Recent events section or pings in your Pings graph, your agent is not working correctly and cannot log Internet and connectivity problems.
One of the tests involved in connectivity monitoring is source/destination ICMP. It also uses standard ports port 80 (http) and 443 (https). If your agent cannot fully communicate with our network, it will not be able to log and confirm problems for you. If the installer didn't have full access to the operating system, it is possible that it was not able to set the firewall and allowed communications for the Windows agent.
If you suspect this could be the case, visit the agent dashboard, click on Manage, the click on Re-Install keeping the following in mind.
MUST install with full admin privileges. If installed on Windows, you must be logged in with FULL administrator privileges. Installing without full administrator rights could prevent the installer from updating the Windows firewall and/or could prevent the agent from communicating altogether.
Firewall/virus scanner. The Windows machine running the agent may be blocking ICMP with its firewall or virus scanner.
Network firewall. No matter if using our PC software or our hardware agent, the local network router/modem firewall may be blocking ICMP.
Uninstall previous version. On Windows, if re-installing an agent, remove any previously installed agent if one is already installed. If an agent is already installed on your PC, the installer will only uninstall the previous version then end. If you did not save the file to a location that you know on your PC, you will have no way of restarting the installer.
Rather than installing directly from your browser, it is best to download and save the agent to a known location on your PC so that you can restart the installer if it ended after removing a previous version. This is not an issue if you do not have an agent already installed.
Updated Windows. Some may find that the installation fails. This is usually because Windows is not fully updated. Please update Windows before installing the agent in case the operating system is missing a required MS package. Win7 MUST have at minimum service pack 1 installed.
How do I know when my agent is working properly? You will know when your agent is communicating correctly once you see 'sending updated hops' in the Recent events section of your dashboard and pings coming into the Pings graph further down the same page.
E EchoMin marked this topic as a question on
E EchoMin has marked this topic as solved on
