Let me first ask if I am interpreting correctly your setup...
For what I see you are asking the service to check every 15 minutes if the TCP port 65201 goes down and in the historical section you don't have any report.
If my interpretation of the setup is correct then I confirm that no error has been found so far, i.e. port 65201 never went down from the moment you set it up.
