Notice: support.outagesio.com is now support.isptracker.com.
Use your app.isptracker.com credentials to log in here.
ISP Tracker monitors Internet disconnections, provider outages, and speed tests for Windows, Linux, ARM32/64. Learn more |
Agent keeps going inactive / disconnecting
My bad: the time I gave you was MST not UTC so all fine with the 2:25 (almost 2:30) pm
What I think it is happening is that the agent has a wrong date which is kind of weird!!!!
Pings are coming in and hops came in too but with wrong dates
Let me see what I can do
I have been able to change the date and time right now but the NTP is not working so the agent's time is not exact (almost 1 min off)
All agents are in sync with the ntp.org servers so either the port or the URL are somehow blocked
All the confusion in hops and pings is in fact associated to the date and time sent by the agent that remained stuck to Aug 16 when it was prepared and shipped.
Pings are coming in correctly, you should see them and hops too.
I will change the historical data so they can fit the correct timing but the issue of the NTP not working properly on that agent is still unsolved. -
Can you allow this IP xxx.xxx.xxx.xxx to access only that agent ?
I have requested a remote reboot of your agent to see if it keeps the NTP configuration but it didnt come back nd also i noticed an outage when I lost the connection
I am still waiting the agent to come back online
I am not 100% sure of what caused it yet, so please if it happens again let us know.
